Hood
- Carnoustie, Scotland
BothAre these all the same or are some better than others?
its just Chinese stuff, all same in a way, i have seen a good dozen or so from different sellers/product name etc.Informative but unhelpful![]()
How much does that cost you a litreYes you can do that - but I run mine on Kero all the time - far cheaper and cleaner.
49p at the moment. I buy 1000L at a time. They fill an ibc for me.How much does that cost you a litre
As low down as possible. Mine is four inches off the floor.Now it where best to put it. got a few places in mind but while in there today sorting out ill make a shelf for it ready.
Now you’re bragging. Mine is four inches off the floor.
Only got 6 inch legs thoughNow you’re bragging![]()
felt a bit of difference aswell in the workshop. He prays a lot.Only got 6 inch legs though![]()
Pump needs to be mounted on it's rubber block not touching anything.Thats trouble, little space now ha ha, plenty higher up but i get what you mean as low as possible.
And it arrived already today juts ran it up for 10 mins and it works atleast. So there a bonusfelt a bit of difference aswell in the workshop.
Dam noisy though, ticking of the pump and blowing of the heater. dam site noisier than others i have heard running. And my Propex heater i had for ages. Ill see how it goes as that will do my head in, So if it is like that all the time i mite box it in outside and vent through the wall.
Its set up as it came. i added the silencer which worked ok. Its the ticking of the pump and noise from the blower.Pump needs to be mounted on it's rubber block not touching anything.
Exhaust can be very noisy have you used the silencer? Some people make huge ones.
I haven't bothered - on a noisy ind est.
That is the drawback of the all in one I suppose. Mine is mounted externally with just ducting running inside.Its set up as it came. i added the silencer which worked ok. Its the ticking of the pump and noise from the blower.
Thats what i ma thinking of doing, i have a canopy/overhang at the side of the workshop so i mite box it in under there and vent into the workshop. Its higher up but ill direct the warm air down and all around.That is the drawback of the all in one I suppose. Mine is mounted externally with just ducting running inside.
