GraemeVW
- Chesterfield
You can't run a two speed motor on a normal vfd
This is what I thought I'd read before.
Am I right in thinking you can wire the motor for one speed and then use one?
Not certain on what levers you are referring to , if you mean the speed changing lever it's a big contacter behind it that has a heavy spring detent that switches the 3 phases.
This was the motor plate on mine I assume yours would be similar but a lower KW ?
I just Took this pic
I have a few questions you might be able to answer actually, mind if I send you a PM?
The motor is rated at half the speed as @Lewis_RX8 's motor.
It could have different pulley sizes or gearing - all I'm saying is be careful of comparing apples with pears.
Can I not just bang a single phase motor in it?
They did do this lathe in single phase.
I assume though that using a single phase motor I'll have no way of getting the low speeds, where if I used a 3 phase motor, I can at least vary with a vfd.
If I could use the original speed change switch to switch between 2 settings on a vfd, that would be ace!
Could easily be done. It's undoubtedly a rotary changeover switch. Depending on the switch you could probably have more speeds as well. eg 1/2 speed, full speed, 1-1/3 speed and maybe even have a v/r controlled speed.
Certainly it's better to try and use the gears *first* then vary the motor.
With a newer VFD rated motor you can go down to 5Hz and up to 75Hz (some will do higher) but with an old motor I'd be wary of going too far either way, although with a 2 speed you do at least know it's ok to run at half speed. I'd probably keep it 25Hz-60Hz.
@Ubique
This is the speed change plate
I don't really know why 4 are blue and 4 are red.
I'm going to assume the top 8 are with the motor of full speed and the bottom 8 on half speed.
If I had to choose one motor speed I'm not sure which I'd pick.
Can't help you there - i'm sure someone will know better, my first thought would be to pick the lower range and overdrive to get the higher range - the benefit of a faster speed is increased cooling so if the motor is working harder, at least it'd be getting a corresponding better airflow. doing it the other way round, you'd be driving it slower but losing some of the airflow cooling. Maybe a VFD rated motor (and VFD) is the way to go?@Ubique
The range of spindle speeds differed slightly according to the year of manufacture. Machines produced immediately prior to the 1950s Student and Master usually had a rather slow range, from 20 to 550 r.p.m., with the new models much faster at 52 to 1000 r.p.m. and later further improved to 54 -1200 r.p.m., both with eight speeds. Two-speed motors were a costly and hence infrequently fitted option, but gave sixteen speeds from 34 to 1500 rpm or even, on some very rare, special-order models, 17 to 750 rpm.
really? you had a static go bang, just from switching?Statics are just waiting to go bang. Especially with switching loads, forward reverse Et
Rotary phase converter is reliable and simple.
last one we had we sold via this forum for £600
