Weber dgas gasket?First TPU print. Seems OK but was a little stringy. It also caused a nozzle blockage for some reason, but not until the end of the printing session.
Weber dgas gasket?
It is in the code, which you can edit in any text editor. The easier alternative is to tweak it via the "tune" function, once the code runs in the printer.silly question time again
downloaded a pla temp tower from thingverse, it automatically changed the bed temp and the print temp.
trouble was the bed temp started at 40 degrees which i cant get it to stick at....
how is this coding done? it step changes the temp on layer levels ? i am using cura and if it is capable o it, i cant see where?
see what you mean......just looked at the code....It is in the code, which you can edit in any text editor. The easier alternative is to tweak it via the "tune" function, once the code runs in the printer.
not looking againCleaned up the stringing and I suppose that they are useable.
