Screwdriver
My first thought after reading your post
Wow! Dunno how that happened but that hit the spot. Man that is DARK!
I don't remember that video being quite so disturbing. Awesome. Thanks.
Re angled cutting ........Have you tried using the Bosch blades that have internal ground clearance cutting edges & smooth outer edged sides like a Japanese pull saw blade ... instead of an external saw set tooth ? Think they may be for cutting laminate or worktopsBit more done.
Scraps of wood and glue as per my recent 'sculptures'.
Then levelled as best I could with an electric plane and belt sander.
Cut out with a jigsaw that refuses to cut vertically (probably me), then sanded.
Just need the thread and nuts I ordered to turn up now.
Yes but 500mg 3 times a day stops it.Does it drive you mad?
![IMG_20211111_100859526[1].jpg IMG_20211111_100859526[1].jpg](https://www.mig-welding.co.uk/forum/data/attachments/314/314875-d88be9d8394eb0fa05ba42d7ad61ede2.jpg?hash=2Ivp2DlOsP)
![IMG_20211111_102846189[1].jpg IMG_20211111_102846189[1].jpg](https://www.mig-welding.co.uk/forum/data/attachments/314/314876-d84d5302521531d4103274d1fada50bf.jpg?hash=2E1TAlIVMd)
![IMG_20211111_104929019[1].jpg IMG_20211111_104929019[1].jpg](https://www.mig-welding.co.uk/forum/data/attachments/314/314877-839d34c178c420f5a46431bbc00235e4.jpg?hash=g500wXjEIP)
Unfortunately it has not improved my Tig abilities one iota![]()
Can someone point me at the kind of blade being recommended here, please? I have to do something similar using my jigsawRe angled cutting ........Have you tried using the Bosch blades that have internal ground clearance cutting edges & smooth outer edged sides like a Japanese pull saw blade ... instead of an external saw set tooth ? Think they may be for cutting laminate or worktops
Screwfix ?Can someone point me at the kind of blade being recommended here, please? I have to do something similar using my jigsaw
Cheers
Worked for me.You need to buy a helmet with flames on it.
Cheers!Screwfix ?
https://www.screwfix.com/c/tools/jigsaw-blades/cat5980008?suitablecuttingapplication=laminate
A physical visit to view is recommended .
My helmet has flames on it but no fire .Worked for me.![]()
