Hi all,
Reaching out to you guys that may know more about compressors than I do!
I recently purchased a second hand SIP 100L 3HP twin v style compressor. It had a fair bit of oil in the tank when I first drained it.
So I did a complete strip down and restored it - made new gaskets, replaced the rubber piston seals and got the scoring out of the bore with the help of a machine shop.
I've ran it for about 30 minutes since and it's very inefficient, taking about 7-9 minutes to reach its 9 bar cut-off. Air also seems to be coming out of the dipstick vent hole.
Stripped it down once again and found oil in the head with more scores on the cylinder:
The piston looks similar to the ones you get in oil free compressors with those rubber compression rings :
I'm now trying to hypothesise as to why this is happening. I can think of two things:
1. Piston misalignment with crank. I initially assembled the piston to the crank first then placed the cylinder over the piston. I've noticed a gap between the piston end and the retaining circlip.
2. Piston seal rubbing with an imperfect cylinder wall, trapping bits of metal in the oil and scoring the bore. Allowing oil to pass through over time.
Any ideas on where to go from here?
