Nick DV
"That's the only name they ever gave me."
- "A long time ago in a galaxy far, far away...."
Thanks Brad, I'll give that a try28V, 12.0m/min would be a good starting point
If it's 32v under full load I'd be very surprised... I bet it's closer to 28v at 240 amps. But i could be wrong. Some machines drop voltage more under load than others.Oxford say that max volts is 32V.
I wanted to find out what the voltage range was for my machine as the handbook is pretty useless, so I asked @Tom Orrow L to find out from the lads that make the mig and they said the range was 16V - 32V. I didn't opt for the volt/amps read out on my machine so I can't really check.If it's 32v under full load I'd be very surprised... I bet it's closer to 28v at 240 amps. But i could be wrong. Some machines drop voltage more under load than others.
CloseWhat do you recommend as the CTTWD in this instance?
I can't really say tbh, I know what "feels" and looks right with an MB36 or bigger torch, but I'd say I'd struggle to gauge it properly with a smaller torch.Fair enough, I guess I'll have a play and find outCloseI can't really say tbh, I know what "feels" and looks right with an MB36 or bigger torch, but I'd say I'd struggle to gauge it properly with a smaller torch.
If you had read my original reply properly, you would have noted that I advised " as much wire as possible" this wire pushes the arc deeper into the weld pool: spray transfer occurs when the voltage is raised above 27v, the advice is not simply erroneous... Which is incorrect. Its the extra wirespeed that gives you the penetration. The extra volts just wastes heat in arc length.
Sorry Robert, I know it works for you, but it's simply incorrect advice. It always has been, and always will be.
Do you mean “stringer”?Its very simple Nick, assuming you are double beveling your stinger bead is the most important and needs to be sufficient to correctly fuse both pieces of metal together on one side then turn it over and weld into your bevel with enough power (turn it up if necessary) to weld and fuse both bevels on the opposite side and into the stinger bead on the other side, from there torch angle becomes more critical as you need to fuse the stinger beads into the sides of the bevel to make your multiple passes.
I find that terminology, particularly unofficial terminology, varies from place to place.Do you mean “stringer”?
That’s what a stringer is, but I’ve never heard it referred to as a “stinger” before. I had assumed that’s what he meant but wasn’t sure on the terminology.I find that terminology, particularly unofficial terminology, varies from place to place.
I believe . was referring to the root bead initially and then stringer beads for subsequent passes - assuming that subsequent passes were laid without weaving.
There was probably an unhelpful auto-correction.
Jack
Easiest way to do it is to make sure you're in spray transfer, you'll (generally) get plenty penetration that wayI
I guess it was an unintended auto-correct. A Stinger (originally a product name) is slang for an electrode holder. Very common in some places.That’s what a stringer is, but I’ve never heard it referred to as a “stinger” before. I had assumed that’s what he meant but wasn’t sure on the terminology.
Yes I know what stinger refers to as well, though it’s probably not as commonly used over here. Maybe it was autocorrect, I have my own suspicions as to the cause but there you go, let’s not detract from the thread any longer .I guess it was an unintended auto-correct. A Stinger (originally a product name) is slang for an electrode holder. Very common in some places.
Jack
Thanks for your input Robert. It's interesting to see/hear how different welders weld, but nonetheless, it's all good for stimulating the little grey cellsIf you had read my original reply properly, you would have noted that I advised " as much wire as possible" this wire pushes the arc deeper into the weld pool: spray transfer occurs when the voltage is raised above 27v, the advice is not simply erroneous
Thanks MM, I understand. I was originally thinking of a single 'V' bevel. I'll have to have a go with a double - once I grab some more thick steel.Its very simple Nick, assuming you are double beveling your stinger bead is the most important and needs to be sufficient to correctly fuse both pieces of metal together on one side then turn it over and weld into your bevel with enough power (turn it up if necessary) to weld and fuse both bevels on the opposite side and into the stinger bead on the other side, from there torch angle becomes more critical as you need to fuse the stinger beads into the sides of the bevel to make your multiple passes.
Thanks Bob. I take your point but I'm a pretty inexperienced welder and when I'm learning new stuff, I like to understand what's going on and why, as opposed to just ploughing on blindly and hoping things work out. If I know why/how something works, then I can eliminate most problems before they occur. I also appreciate everyone taking time to answer my silly questionsThats about it, I am not sure why folk get so hung up on "settings". Should be obvious through the lens whether you are getting penetration and what needs an immediate tweek on the settings.
Bob
Thanks mate, and 'simpler' is always goodYou're welcome Nick, a single bevel creates heat distortion and a double bevel equalises this by pulling in the opposite direction and your work remains flat, think of it as a halfway house to sequence welding, but simpler and done at home.
I've managed some really thick stuff maxed out at 200 amps, with multiple passes, but it was for my personal use and not structural (before someone leaps in). The whole piece was glowing red hot (which might not be tolerated) and fusion was good. As someone quite rightly stated the root has got to be good and successive passes are just a repeat of the same. I am NOT a professional welder, but have been mig/tig'ing 30yrsThanks for the response. I will get hold of some thick plate as you suggest and have a go.
My mig is 240 amp, so if I take your second welder spec "10mm plate to plate fillet - 1 run at 258-289 amps spray arc flat", this is not going to be possible as it's above the mig's capability. Therefore, would my machine be capable of a multi pass run to produce a strong weld, and if so would the root pass be made with the mig at full whack?
Of course I may be barking up the wrong tree, and it's as simple as if the mig can't weld a certain thickness in a single pass, then it won't be able to do so using multiple passes?
Perhaps I need to stop watching 'experts' on Youtube!![]()
Thanks Ed, I fully appreciate what you are sayingOne thing that wasn't mentioned is that on a 250A machine, to be mindful of the duty cycle, weld for too long at max amps and your unit may just cut out if it has a temp control switch, if it doesn't, it may reduce the output of the current mid weld and in the worse case you may end up needing a new circuit board. A lot of 250A 240V welders are overrated regarding their output and/or have poor duty cycles at max amps.
Thanks Prep, it’s time I gave it a go as it’s the only way I’ll find out, but getting hold of thick pieces of scrap to practice on isn’t easyI've managed some really thick stuff maxed out at 200 amps, with multiple passes, but it was for my personal use and not structural (before someone leaps in). The whole piece was glowing red hot (which might not be tolerated) and fusion was good. As someone quite rightly stated the root has got to be good and successive passes are just a repeat of the same. I am NOT a professional welder, but have been mig/tig'ing 30yrs
By thick stuff I mean.....Thanks Ed, I fully appreciate what you are saying
Thanks Prep, it’s time I gave it a go as it’s the only way I’ll find out, but getting hold of thick pieces of scrap to practice on isn’t easy![]()
This is 3 pieces. No it hasn't been dye-penned, but has been tested in anger many times. They are ALL root welds built up with multi-passes. Ground up to finish off. I use pub gas CO² always have and being a cheapskate always will.
Maybe confused with 'Singer' who made sewing machines?I guess it was an unintended auto-correct. A Stinger (originally a product name) is slang for an electrode holder. Very common in some places.
Jack
Are you saying this was with a 200amp welder?By thick stuff I mean.....View attachment 331386This is 3 pieces. No it hasn't been dye-penned, but has been tested in anger many times. They are ALL root welds built up with multi-passes. Ground up to finish off. I use pub gas CO² always have and being a cheapskate always will.![]()
