Yeah I thought about that as an option. Any ideas how much it would cost to hot dip a cutting deck?Why not steel and hot dip galv?
What thickness steel is that Bob?@Bobupndown , best pics I can do:
Notch the flanges with a slitting disc. I went every 10mm. Bend tabs up / down. Bend round the mower deck. Just tweak till it fits.
Cut the overlap off:
Weld the resultant gaps up.
Sorry, got confused - thanks.It was me and I used 2mm mild.
I had one of the almost flat spinning lawn sprinklers set o a piece of blue plastic water pipe used on a concrete wash pad area for under washing things , I used drive over the hose , pull it under the deck turn it on & carefully wash underneath the deck over a few minutes duration , after each use then drive it into the dry airy shed where it lived .Clean grass out regularly, apply corrosion inhibiting compound.
That is all.
IIRC in the early 1960's Hayter used to do an aluminium deck for a lot of their mowers but they suffered from corrosion due to dissimilar metals being used . I've often wondered why no- one makes a quality fibre glass deck instead . I'm too old to bother now ( 71 yrsold ) I've downsized from 2 acres to two tiny pocket handkerchief lawns & a bungalow .Why don't they make them of aluminium, then it'd be a job for lifesuppose they'd not sell enough lawnmowers then.
I have a brand new mountfield sitting in the garage, haven't had it on the lawn yet and just know as soon as its used the decay will start, have to make sure I clean it properly and use some sort of rust inhibitor on it over the winter. I have had only 2 petrol lawnmowers over the last 24 years, normal self propelled jobs, 1st was well patched and welded then the engine seized. Bought a new one which must be 10+ years old now, also patched and repaired but still going strong![]()
