Luggsey
- Devon
I watched a u-tube yesterday where a body repair shop has a small air grinder that uses worn down standard 4" grinder discs in a small pistol shaped air tool.
[I know old worn discs can shatter!]
Anybody know how you do this as the only adaptor I can find is a shaft to angle grinder so you can make a drill use grinder discs.
The reason to ask is 2" grinder consumables are expensive and you can obviously use old 4" stuff on a smaller setup letting you clean up stuff in restricted areas.
I'm thinking a 2" air grinder with adaptor maybe but 'how to' is the question?
