- UK
Having some trouble here. 3 combustion caps on the side of a Perkins P3. New copper sealing washers on the original caps, leaked. Heated the washers to soften, leaked. Used Permatex copper gasket spray as suggested by @Pete. , leaked. New combustion caps, new copper washers, leaked.
Studs are as tight as I dare without snapping them.
Side of the head is machined perfectly flat so i'm at a loss. I've used Hylomar Blue on just about every other joint on the tractor and it is totally tight as a drum with no leaks on anything. Would Hylomar Blue be ok on this - it will get hot - so i have avoided using it.
There's another slight issue with combustion gas shoving the coolant out of the filler cap and diesel leaking out of the head gasket, but we'll come to that next
Thanks
Thanks
The surface must be either distorted or corroded then, surely.
