I was driving through a local hamlet last week & I felt a bump under the van. I thought I'd run over something on the road & in the mirror I could see a wheel sitting on the road!
That's strange I thought, I didn't see that in the road.
Then it clicked, was it my spare wheel?
Pulled over & sure enough my spare wheel was missing!
Went back & rescued the wheel & threw it into the van. Then I looked to see how it got loose.
It lives under the van in a metal frame pivoted at the front & secured by a hook that is tightened by a long bolt from inside the van. Looked under the van & the hook had managed to unscrew itself & was missing!
When I got the van the hook was seized onto the bolt & it took a lot of heat & swearing to get it separated. I cleaned it up & refitted it with lots of copper grease but I was really surprised it had unscrewed itself!
Luckily the hook was lying on the road so I could at least get the wheel cage lifted into place again.
It was really lucky that this happened where it did,with no traffic around!
I've now added a short security chain from the wheel carrier to the tow bar frame so it can't drop if the hook fails & I'm going to put a short roll pin on the end of the bolt so that the hook can't unscrew completely.
