I picked up a 20L Argon Mix Cyl tonight, & have been in the Shed to hook it all up and try out my new Paton on solid not wire and gas for the 1st time.
There is no info in the bumf from WSD, just some fittings and a short length of pipe.
I fitted the Parweld Reg, & the only way one end of the pipe seemed to fit (a stub pipe onto the Reg, and a QR fixing for the stub that goes onto the tubing supplied nicely.
Ok so far.
But.. The fitting on the back of the welder body.... looks like a type to accept a different kind of QR fitting? If it does.... then I wasn't supplied with it.
The tubing is too small a bore to push fit and then jubilee clip onto the welder end fitting - so i have no obvious eay to connect the supplied Reg to the supplied Welder
Am I just being thick, or am I being frustrated by a missing part? As it is I can't use the welder cos I can't get the gas connected.
TIA. G.
Ok so far.
TIA. G.
