lotus_esprit_s1
- UK
Rebuilding the front axle of my Puma Defender. It is running a stronger differential setup due to the original factory diff letting go on the first owner. I am doing some work on the front axle so pulled the diff to check backlash and found that one side would not adjust up. Stripped the diff centre out and found unusual wear pattern in the bearing on the side which wouldn’t adjust.
The diff carrier has been modified with a known “pegging” modification to strengthen it, however it appears the welding involved with this mod has distorted the carrier fractionally, causing the bearing race to distort when clamped up - when the race is dropped in the carrier, it sits approx 1mm off, however will slot down easily, but is distorting when pushed in place. I am pretty much resigned to buying a new modified casing at £300, however as I have nothing to loose wondered if this case could be rectified. (Due to the modification, the locking centre has been modified to suit and requires a modified casing)
Any ideas? I did wonder about strategically welding the case to try and pull the sides of the diff carrier outwards.
Hopefully the photos help describe the problem - green arrows show where the bearing is being distorted
only time I’ve blown diffs is driving like a loon in a trial
