DAPPH
as dyslexik as I'm daft
That's one rather top heavy bench , It'll be a shame if you waste the storage space under the bench . ( I know you said you'd be thinking of it ) .Made a frame for "The Heavy".
I can move it around the workshop on my own... Just.
Will use it a bit and maybe make some storage on it before painting it.
View attachment 315794View attachment 315795
Weld a four bottom shelf hollow tube bar set on it and cover it in 20 mm construction ply & weld on a towing eye or two at each end , you can always use a 6 foot length of 3x3 " or an anchored block & tackle set with six to one pully's on it to move it around when it's reasonably loaded up .
Plus a bottom bar set will give it tremendous strength & when loaded a lot more stability .
