brightspark
- yarm stockton on tees
i have a Formica topped bench it came from a butchers
you would have to have wings to beat the scrotes to themCover it in the cut up sides of abandoned domestic appliances?
you would have to have wings to beat the scrotes to them![]()
same here after grinding because a rag was smoldering once and i fortunately saw it 12 minutes lately . i watch where the sparks go now and when welding check the bottom of my trouser legs make sure there not on fireI have plain old mild steel bench tops - they were painted with machine enamel, but most of it has vanished with the benches being used. They haven't gone rusty.
I'd be worried about having a wood surface near to welding - especially one coated in paint, varnish, oil, etc - seem to me to be perfect fire starters from a few hot sparks landing on them.
I'd have kittens welding in some of the places that get pictured on here - wood, dust, old chairs, cardboard, rags . . . all look to be a disaster waiting to happen to me. Even without all that around me, I still go back in a while after welding just to check there is nothing quietly smoldering in the corner.
Can you still get that really thick linoleum? I’ve had my bench covered in a piece of that for over 40 years and it’s still in good nick. I would love to cover the benches in my new workshop with the same stuff.If the bench is going to get greasy, consider laying a piece of linoleum over the plywood.
That’s made my mind up. I’ve been toying with using scaffold boards for a woodwork bench I’m making and yours looks like just what I’m after. Timber is so expensive at the moment.My bench has 40mm scaffold planks as the top surface. They were new and varnished at the start of this year. A bit of welding, grinding and oily bits and pieces on it and it's starting to get some 'patina'. Plan to get a sheet of 2mm steel to cover it, hadn't thought of galvanised but am now!View attachment 314491
I'm undecided what to cover it in,
Yup I've always left em as is and made sure there easily replaceableI just use time. After a while the veneer develops a patina, typically a cocktail of WD40, petrol, oil and whatever else might get spilled on the bench. My current naked plywood bench top has been used for at least ten years and has no noticable damage. Certainly nothing that would have benefitted from a varnish.
By sheer coincidence, I am making up some "upcycled" drawer units and the client likes the raw used look of it. So I have just been experimenting with Danish oil/white spirit etc.
Would have been much easier to blast it with paint but other than the effort of tidying up all the urethane spillover and edge banding the ply tops, it actually looks quite nice. Even the MDF seems to like a thin coat of Danish. Will also test some linseed oil which I think is pretty much the same thing and rub it down with a beeswax polish to finish.
Any of those sorts of treatments will be fine for a workbench because they will make you go over it with a sander, it helps prevent minor splintering and can be reapplied whenever you feel like it (i.e. never in my case!).
It was only just finished in that picture, not looking so pristine now!Tidy envy!
Yeah, I think a piece of thick linoleum will suffice well.Can you still get that really thick linoleum? I’ve had my bench covered in a piece of that for over 40 years and it’s still in good nick. I would love to cover the benches in my new workshop with the same stuff.
cheaper than the steel for sureNice build there.Just gotta mount the ancillaries and it’s done…
I used yacht varnish for the lower shelf and polyurethane on the top, both gloss for practicality of cleaning. It’s a first attempt at producing a bench, it’s turned out ok, very flat and relatively plumb.
ThanksNice build there.
Consider turning the wheel lock tabs under the bench, to save your toes from agony in the future.
Steel toe capped boots when I'm out there, it's at the end of the garden and so the likes of slippers or socks ain't really feasible.My bench has 40mm scaffold planks as the top surface. They were new and varnished at the start of this year. A bit of welding, grinding and oily bits and pieces on it and it's starting to get some 'patina'. Plan to get a sheet of 2mm steel to cover it, hadn't thought of galvanised but am now!View attachment 314491
