Brad93
- Essex, United Kingdom
Well that a nice set!
Annoyingly much too big for my latheWell that a nice set!
I was looking to upgrade the Myford from ER25 to a drawbar setup so looked like just the job. Sigh will I ever learn.They looked like 3c from here too.
Do you need a set or just filling gaps? I have some spare.
4MT was a guess as common for 4C collet adaptors I haven't measured it.4MT, that's a shame. My headstock is 4.5
so what are you using the rcd onI acquired a three phase 63amp consumer unit courtesy of @Welderpaul View attachment 314462
And a load of 6" fittings for my flowbench.
Looks to be a generic "4x6 bandsaw" (lots of hits on Google).Some days ago my local men's shed acquired some more freebies from the same generous source that provided us with a very decent anvil, a swage block and a large bench shear. Four items in total: a Draper bandsaw, a Sealley pillar drill, a Miller Integra 201 MIG welder and a pretty big cut-off saw with a 16" steel blade (can't recall the name). I went to take photos of them all but the batteries on my camera died half way through the session.I'll add shots of the MIG welder and the cut-off saw next time I'm in the shed.
It needs a bit of a clean up but is working perfectly and, once I'd reset the vice, is cutting square. Cuts dry and the feed is a case of balancing spring tension against weight. Any info on this saw would be appreciated.
You missed off add grease/oil to the gearbox before it self destructs!Looks to be a generic "4x6 bandsaw" (lots of hits on Google).
Available in umpteen colours, with very slight alterations, for at least the last 20yrs from a myriad of suppliers.
Mine is from "nutool", but I've seen Clarke, Axminster, and Sealey badges on exactly the same saw.
The bent metal stand is rubbish, but the saws themselves are actually pretty good once fettled.
There are LOTS of websites and threads on various forums across the internet detailing mods/improvements and info on them.
First thing I'd do is get rid of the stand.
Then add coolant.
Then a hydraulic feed.
If you're looking to move them on, would you be able to bung up a few pics and dimensions please?I was looking to upgrade the Myford from ER25 to a drawbar setup so looked like just the job. Sigh will I ever learn.![]()
Wish you had not posted now collet envy
My Dad started a compound marine engine but never finished much past the castings with no real plans drawn up hopefully this will give more incentive to carry on and figure it out a steam supply was one of the barriers this is how far I got.What are your plans for it?
I acquired a second hand one recently and agree with you that it's a very good saw for the moneyLooks to be a generic "4x6 bandsaw" (lots of hits on Google).
Then add coolant.
