I think with the limit switch not made even with the button pushed the coil wouldn’t pull in as it’s in series with the coil if you see what I mean?Would be worth checking the limit switch as well, I think that o/l in the motor is just an over temperature thing
Your correct but I was thinking more of it being made when the machine is off and as soon as its started the vibration is causing a break somewhere? what does the limit switch do? shame 5mins with a multimeter and it would be a doddle to sortI think with the limit switch not made even with the button pushed the coil wouldn’t pull in as it’s in series with the coil if you see what I mean?![]()
Ah maybe, yeah a multimeter would find it pretty sharpish.Your correct but I was thinking more of it being made when the machine is off and as soon as its started the vibration is causing a break somewhere? what does the limit switch do? shame 5mins with a multimeter and it would be a doddle to sort
That is a funny looking thing. I presume that C2 is definitely a capacitor in which case it reads to me that a combination of C1 and C2 keep the coil energised at switch on through a potentially long or intermittent feed from the switch.There is the device marked 'n' next to C2, it's possible that is the thermal fuse but it's not a symbol i'm familiar with. you need to be following wires to get to the bottom of things, although the thermal fuse you've bridged out has definitely failed! The motor is an induction type so there won't be any brushes etc. pinging out if you take the end caps off to have a look inside.
