Thanks! Anyone else know the manufacturer?Don't know the brand, but I've seen one of these used in the past by a fellow Benchrest competitor, for resizing and seating bullets. Very nice indeed.![]()
Thanks, I’ll have a closer look.Look for WD or MOD marks.
Base or webs.
A lot of round makers used similar to do test loads.
Does not add ££££, but adds history.
Did the dies come with it?
Yeah, that’s the main reason I bought it (and I thought it was cheap for the quality)Wow. That's got quality written all over it.
Hah, interesting, I bought a slip gauge set by them as well last week. Matching set.
Are those phos bronze or steel fingers?
Steel, polished ends with a bevel edgeAre those phos bronze or steel fingers?
But you didn’t say what I might need (or use it) for? Or how?They would be steel, hardened and ground, possibly lapped. Looks like they are gripped by split cotters.
The aluminium plate on it looks to have its set range on it (0.442"-0.447"). The other stamping would be the toolroom reference. The 1/4"-1/2" on the other side is the range the body can accommodate. I think the plastic grips are so you do not transfer your body heat to it.
Go/No Go gauge, you set the top anvils to the max allowable size of your part, you set the lower to just under the min allowable size. If the part you make passes the first but doesn't pass the second it is within tolerances. If it passes both it is too small, if it doesn't go in the first it is too big.But you didn’t say what I might need (or use it) for? Or how?
Could be, the joker at a tool shop in Dorset had a lot.No, it's a thread Go/No-go gauge.
