Do it as a series of spot welds with a big gap between each? Use an air line to cool the metal between welds....I'm going to have another go. This time I'll Dremel off the galvanising from the inside of the cowl. What I found when welding was that it'd seem to be going fine then I'd hit like a pocket of "gas" and a bit of the cowl would hole/disappear. Pushing forward with the torch seemed to work, starting on the thick tube then edging the molten pool up to the thinner cowl material to fuse it.
Someone suggested trying 0.8mm wire might be easier?
bodywork is always a tough one, rarely you can run a proper bead on it unless you have a super smooth welding machine and some decent thickness of sheet.I'm thinking I'm limited on settings with this old welder? Presumably with a modern, inverter mig you can just turn a dial to set the amps?
I know nothing mind... I read it in a book....![]()
You need a shedThat was the plan. A proper pita having no specific, secure, covered workspace. Having to first fetch the welder, then the bottle now the compressor all onto the patio. You're always hoping it doesn't rain then having to put it all away again after.
thats how it starts! he will be looking at lathes and in his household fuse box to see if he can eeek 3 phase out of itYou need a shed![]()
100A might work but you're going to need someone else to watch it when you are welding. Also won't cover the full range of the welder which is 130Amps I assume.
I've just ordered a 50A for my diesel heater from China. Delivery date is February next year!![]()
