james butler
- birmingham england
amprobe and even top clarke multimeters are pretty good
It should last decades if correctly used and respected.A multimeter seems to last me decades
).I sold a Fluke Scopemeter, 88 Automotive and an 85 true RMS in the last couple of years, I'd previously bought them all as used and sold them for at least as much as I paid for them - and yes, I'm a Yorkshireman.It should last decades if correctly used and respected.
Someone needs recalibration once in a while , both instrument and operator , one by using a software , and the other by using a big wrench.![]()
My go to meter is a megger built in 1984... I can't get it calibrated any more so check it against a calibrated unit ... its also not needed adjustment in 15 yearsA multimeter seems to last me decades.
I have 2 of those, one convintional the other clamp or lead version. They are good and good value much better than a Draper or Seeley. The clamp one I bought because it has frequency in Hz as i have a generator and work on gennys at times. Even tho my own genny has its own LCD frequency meterI've been using my uni-t one for over 10 years and it's never let me down, can't justify a fluke for how often I use it.
That was exactly what I used mine for - sold the lot and bought a 2 channel PicoScope, that does everything the fluke kit did, and more, for way less than the Fluke kit sold for. I still need DMM's though, the 300FC analogue bargraph isn't a patch on the 85 but linking it to the PC software gives a much more useful picture.I got a Fluke 88V - I really only use it for Hz % pulse width. (nobody would want to buy mine - it is in a hell of state)
the leads will just vapourise. Flukes etc have a proper HRC fuse inside.That was exactly what I used mine for - sold the lot and bought a 2 channel PicoScope, that does everything the fluke kit did, and more, for way less than the Fluke kit sold for. I still need DMM's though, the 300FC analogue bargraph isn't a patch on the 87 but linking it to the PC software gives a much more useful picture.
Me too, usually for looking for framing faults on Flexray, CanBus or LIN, did use it 'mobile' once to look at data loss on the move, turned out a CAN-H wire had chafed on a body seam, only went to ground when the bump in the road was heavy enough... also handy for doing A-B comparisons either side of connectors or connection nodes.I also got a PicoScope as well... Really only use mine in the workshop.
I'd love to have one of those with the detachable displayand when people say Fluke multimeters are reliable.
who can argue with this![]()
