James1979
- Orkney
Visible numbers should be law.
Some of the modern numbering leaves a lot to be desired mind. Especially on these modern rabbit warrens. You get 1 and 99 next to each other and all sorts.
Visible number is the law in a lot of Germany. For the reasons you say.
In the us as well I think. Some places have it on the kerbstone as well.
Worse than that is names. At least with numbers once you spot a few you can usually work out a pattern. With names you’ve no hope.Ok so if there are flames coming out of the windows it's fairly obvious but often it's not, and every second counts.
