Edward Teach
pre-moderated
- South West England
I've had a quick look at your site, Fair Play
Now that the garage /shed is up and running, I've been using one of those magnets on an extendable handle. Kind of a pain and a mess using a rag to pinch off the swarf on the end and shake it into a bin, so after viewing a couple of videos recently I was looking to fabricate a tool like you bought.View attachment 308710
This magnetic swarf cleanup tool , magnet in a non magnetic tube you push a magnet in the tube to collect swarf then draw it out over the bin and then swarf drops off. Very handy and £18 off eBay will save alot of time in cleanup and save hoovering up so much
Now that the garage /shed is up and running, I've been using ne of those magnets on an extendable handle. Kind of a pain and a mess using a rag to pinch off the swarf on the end and shake it into a bin, so I after viewing a couple of videos recently I was looking to fabricate a tool like you bought.
Thanks for posting, I just decided to order one of these off the Bay. Price was £19.49 at the moment, but as a tool that will be in constant use, its cheap when you think about the time and effort involved in making one. Cheers.![]()
This was my solution
It's multifunction, you could make crumpets on that to go with the coffee![]()
That’ll be the bannock girdles. Also on EtsyIt's multifunction, you could make crumpets on that to go with the coffee![]()
Which is........?They are available on my etsy shop![]()
Man, you really don’t want to see my girdle!Bannock girdles? is that another Orkney fetish thing? if so can we have pictures?
Is it an engraving cutter?This little lot yesterday, guy says, these any good to you Norm? Aye says I, help yourself then so I did. the callipers are (un chinese) Moore & Wright, as is the small set square. The 12" rule is a Rabone. The Item in between the two centre drills I've never came across before, the ID on it is AMBROSE 1 7000/Q12. It's twin fluted and very sharp, It's to sharp angle for a counter sink. May be for diesel pump repairs.
Good shout.Is it an engraving cutter?
