Sorry I'm new to this what does that mean?60v will be the ocv
Nothing changes when moving the voltage dial. The amps dial controls the wire speed and only zeros are shown on that display too. How would I set it up if the voltage dial does nothing?I believe Epace is right as it is an inverter welder and 60v sounds about right its the amps it draws as you weld should go up when you weld thicker metals !!
Voltage doesn't set how thick the material you weld is.So how do I set it up to weld. I was expecting to set the Voltage based on material thickness. I'm a bit confused to say the least. There are no instructions at all.
Thanks
Steve
Direct from vevor uk. No instruction manual at all.Where did you buy this new machine without instructions? Ali or Bang etc?
Looks like they refer to some 'good book' on the front panel:
