Kram
- Sussex
@Lewis_RX8 That does seem past the chuck limits, probably unsafe! But nowhere near the lathes limit. Is it a 7" swing?
There are a few ways around it for example, three holes drilled for the chuck jaws to grip on, or a peice of tube welded - how I did the back plates.
I do have a spare 5" chuck. Its not good enough for my use other than adapting to a welding fixture, but is taking up valuable space, it would allow you to do bigger things if you want it.
Worth looking out on ebay for a decent Pratt Burnerd as small ones go quite cheap and will improve the lathe a lot just from being able to grip parts better.
For tool post you'd put tool other side at some angle to minimise stickout. This is why I made a lefty ccmt tool
www.ebay.co.uk/itm/185008258381
If the seller will allow it, Hermes collection is not expensive.
For bearing/pressing tools, ideally you want something tougher than mild steel.
The problem isn't the machining. It's getting hold of a big enough lump of steel.
This might be near @bR39DaCan be bought on eBay but I think looking at about £35 - £45 for 120mm length of 85mm dia stock not sure if that's reasonable
Stainless is generally nice to turn tho I havent done much with it.
