RaceDiagnostics
- Broughty Ferry
I'm planning on taking out a wall that currently has a radiator on each side so need to remove them. I haven't done any serious plumbing since the early 80s and it seems like things have moved on.
Reading up indicates there are two types of plastic pipes, PEX and PB, I was just about to buy a bunch of JG speedfit end caps from screwfix when I thought about the pipe type. Do I need to worry about the pipe type or will these end caps work on either?
www.screwfix.com
Are the insers also compatible or specific?
www.screwfix.com
Here is the view from under the floor of the connections to the radiators. Unfortunaterly I wasn't thinking about the pipe type when I was under the floor.
Thanks guys!
JG Speedfit Plastic Push-Fit Stop Ends 15mm 10 Pack - Screwfix
Order online at Screwfix.com. 15mm. Push straight onto copper tube. Removable and reusable. No tools needed. FREE next day delivery available, free collection in 1 minute.
JG Speedfit Superseal Plastic Push-Fit Pipe Inserts 15mm 50 Pack - Screwfix
Order online at Screwfix.com. Use with PE-X plastic pipe. Push straight onto copper tube. Removable and reusable. Water Research Council Approved. British Gas Service approved for water pipes. No tools needed. FREE next day delivery available, free collection in 1 minute.
Thanks guys!
