jerrytug
- Isle of Wight
Hi chaps I have had plenty of cars with hydraulic steering, driven from a belt drive pump. On full lock, there is an arrangement which avoids hydraulic lock and belt slipping at full lock, eg manouvering in a car park. But it has never been an issue before.
However on this 205, when you put the wheel hard over, the engine slows a bit, and there is a screeching from the (new, correctly adjusted) pump drive belt.
Normally in other cars this has not happened. There must be an arrangement, and it must be either a simple pressure relief valve, or bypass valves which are opened, by the rack position presumably, at full lock.
Such an arrangement seems to be lacking, and it is surprisingly annoying because I like parking in tight spaces, and the momentary mechanical shriek of pain when touching full lock makes me wary. The belt is new, but the previous one was burned and ragged, which figures..
The steering and engine are both non-standard for the reg. number, so googling for under-bonnet parts is not really much use, 2 belts got sent back before the correct one was found.
(The Haynes book is no help either)
That is why I want to learn, from first principles, how this hydraulic situation is dealt with on simple 80's and 90's frog cars.
On the bright side,someone has shoehorned in a later Citroen 1.9 turbo diesel, and it goes like a scalded cat
Thanks in advance
Thanks in advance
