Did that won't budge. Not in a bathroom.remove the 3 countrsunk screws
Nope both stuck solid. Will try some heat as suggested.If you can get the handle off the other side, tap the square bar to push the other side off?
Good point will check.You don't, they are circlipped on the back of the plate
Another good tip thanks.Work both the handles against each other - push one down and the other up (with both grubscrews out) and you should be able to break any bonds without damaging the door. One side will come off and you can then pull the square bar through or remove it with the other handle.
How long of a handleBFH ?![]()
