Long shot Fizzy, but do you have either another 1/2" UNC nut or bolt to work out which one may be at fault?Made a screw. 1/2" UNC.
Tapped a hole.
Tap runs nicely through the hole all the way.
Die runs perfectly along the screw.
When you place the screw in the tapped hole it goes so far then gets very tight.
Not a split die so no real adjustment.
Any idea why?
I have another tap which works fine but no nuts or other dies in 1/2 UNC. I did wonder if its a faulty die. Came from a cheap set but the fact the first 1/3 screws in ok suggests it is fine.Long shot Fizzy, but do you have either another 1/2" UNC nut or bolt to work out which one may be at fault?
That would be great - let me know thanks.I may have a spare die I could send you. Will look tomorrow
The screw was to replace a missing one in my 4 way toolpost.
The ones in there never want to unscrew all the way but I found one that did.
is the die 100% 1/2" UNC and not 1/2" BSW wearing a stetson to look all modern?
Would it not be BSW anyway being a50/60s colchester?Please do not shoot me for mentioning this, but is the die 100% 1/2" UNC and not 1/2" BSW wearing a stetson to look all modern?
