Olderisbetter
- Wolverhampton
We have been have a big sort out to say the least, while opening old stock i found a wall outlet with this odd T shape on the earth pin, tried a standard plug and no go...
Thanks for posting that. I have seen the T shaped ones but some of the others are new to meHere you go: https://www.plugsocketmuseum.nl/British2.html
That's a whole site devoted to mains plugs and socketry. Hats off to the man for doing it.
or buy the proper ones for about 2 and a half quid used in airports and public spaces to stop un authorized useI’ve seen them used for ‘essential supplies’ that were covered by a UPS and Generator. Same story as everyone else has said, stops a muppet from using them and unplugging equipment/connect high power equipmentWe have been have a big sort out to say the least, while opening old stock i found a wall outlet with this odd T shape on the earth pin, tried a standard plug and no go...View attachment 305110
As @colnerov has said, often used for lighting although these look like 5a round pin as apposed to the 15a that is standard in theatres…In the same box was quite a few round 3 pin
All our CAD stations were on the rotational ones, and some still are I think. Other than the plug being a big larger than usual, theres nothing much to indicate they are special - which has led to some amusementThanks for posting that. I have seen the T shaped ones but some of the others are new to meespecially the rotational ones!
