Agroshield
A guillotine-like cutting action with the grit 'downwards' would give longer cutting edge life than a rotary cutter or a slicing action with a vertical blade. The guillotine is shearing the sheet.
The disadvantage of grit downwards is that it will wear the platen of the machine.
Guillotine or shear blades are easy to sharpen or touch up in situ, especially if straight. You can tune the bevel to suit the cutting conditions. You can also easily adjust clearance between the two blades.
In the metalworking world, you can buy throatless shears (Beverley is one brand) that do not have a length limitation. I saw a picture of an electric throatless shear that might work.
Off the wall idea: laser cutter.
Also, see what is available in the bandsaw world. There are many, many different types of bandsaw blades made other than the standard ones with teeth on one edge. A very fine toothed, PCD-coated or toothless (pure abrasive) blade might work. Fence is already there for alignment. Motorised roller to feed the work (like you see on jointers or spindle moulders).
Perhaps give Abracs or Midland Abrasives a call or the guy on eBay who sells the abrasives and ask them how they cut sheets or rolls. If you sent them five or ten rolls, they might do it for you.
