CompoSimmonite
I'm restarting the thinking about my idea for an amphibious mobility scooter. I know max width (850mm) and weight (150kg) to conform with the rules so intend making the basic "hull" in fibreglass and then putting it in a water tank with concrete blocks to duplicate weight of mechanicals, plus me (120kg
) , to determine ride height when floating. Large boat fenders would be solidly attached when in the canal, pond etc for additional buoyancy but not for design testing.
I think two IBC tanks with tops cut off and joined together would be the perfect size. Intention would be, if possible, to retain the steel cage for support.
Question therefore is how would people actually join the tanks together ? Would DIY plastic welding be sufficient or would getting them done professionally be safer bet ?
If anyone can suggest an alternative to two IBC tanks please let me know. Requirements would be cheap, solid (therefore rules out inflatable pools), not metal so plastic or fibreglass and approx 1200mm x 2000mm x say min of 750mm high.
) , to determine ride height when floating. Large boat fenders would be solidly attached when in the canal, pond etc for additional buoyancy but not for design testing.I think two IBC tanks with tops cut off and joined together would be the perfect size. Intention would be, if possible, to retain the steel cage for support.
