Thanks James that's brilliant, with the high vis jacket tied on the end I should be all good then.![]()
Overhanging loads
www.gov.uk
If in doubt try to make it look legit as possible.Of course its legal, you tied a hi vis to it
Have you secured it?
Make sure it cant bounce up as well as not fall out.Temporarily riged with a tow rope and bungees, ratchet straps are going on this evening. To the tie down points in the bed.
Cheers I'll run some down the outside to the towbar as well then.Make sure it cant bounce up as well as not fall out.
Make it look as safe as possible with visible straps.
Less likely to get a tug then.
So true but work won't allow for that unfortunately. Besides the gate was free music to a true Scotsmans ears. (I'm not a stingy bugger I did give the guy £20 for it)I alway try to plan these things when there is an important football match.
I believe there is ek or wk final soon?
Dmax ain't that posh.if in doubt just stick the vertically thought the sunroof...... no overhang that way![]()
