Simpler to implement
These are all good, but you have to show the flat blank in them as well, not just the finished, closed item. If the tooling is horizontal, the blank can just lie on it but you still have to consider how to stop it moving forwards and backwards, to ensure the bend is the correct distance from the end of the blank.
When discussing with the client, it might be worth finding out how he will install these. If he slides the end of the tube into the clip, it is better to supply to him as 'closed'. If he pushes the clip sideways over the tube, then it would be better to supply them 'open' (and the open option is less work for you making them).
You only have to add up the times you have to handle between processes to know its going to be expensive and laboriousat 4000-off, I'd be buying packs of these, stripping the rubber off them, and selling them on to him
Even that's going to be around £2500-£3000 at best, before you add your cut on... if you were making them there's no way you could make them as cheap as that, unless you had a dedicated production line and based off hundreds per minute...
Think about it... this is as efficient as I could see it in my head in a normal sheetmetal shop:
1. guillotine strips
2. use custom form punch on a metalworker to radius the ends and punch holes
3. punch 90 degree bend in one end
4. hand form the U shape around a form jig
And that's assuming your tooling is minted sharp so you don't have sharp edges to deburr... might get it with a tumbler, not sure...
£2/ea is probably not a bad figure to start from...
£2 was where I’m at to be honest.at 4000-off, I'd be buying packs of these, stripping the rubber off them, and selling them on to him
Personally I would stay clear. Ive been sucked into stuff like this myself, with the thought of "easy cash"
There's areason why some people can stand at a station on a production line doing the same thing day in day out, and this WILL be days. For what will workout as peanuts by the time you have finished them.
and £2/each would make it pay, if you did it just right... be plenty boring after the first 50, though!Its more the 'can I do it' and 'how' than actually wanting to do it so I am there with you on that one.The most expensive part of the operation would be a custom form punch for the ends... you could get by with a generic radius punch and a hole punch, with properly set up fences, but you're then turning one operation into 3 operations, and ironworkers aren't the fastest moving things...
A better option might be to laser cut them, cutting out 3 operations altogether, assuming you can get a tidy finish on thin stainless... and definitely tumble them. The 90 deg fold is dead easy and quick on any sort of machine with a fence/backstop, and then you're left with the U bend. A custom form tool for this would be easy and cheap to make, and assuming 1mm or less, it'll be a hand operation with suitable fences.
Not that I'd want to do the job in the slightest, even at a decent rate... but it intrigues me to work out how I'd manage to do it most efficientlyand £2/each would make it pay, if you did it just right... be plenty boring after the first 50, though!
Only thing that worries me about that is the grade / quality of stainless. I dont want to be going down warranty claim when the 'stainless' starts rusting next winter.I'd get on Alibaba.
China has lines that do this kind of thing and Ali sellers will customise to your demands.
Cheers. Group effortwell done, good result
