angellonewolf
- bristol england
Ok long story short (as possible)
Listed on facebook up for collection free so arranged to collect takes an hour in total getting there and back
Turns up lady said oh I did not know the cable was cut off
Oh well I'm here so took it and a strimmer that was there as the cable was on it
Come home used the meter to buzz out tested ok on the switch so wired up with the cable off the strimmer
Fixed a bit of the metal bent up and then fixed the roller adjustment
Plugged in motor runs but scarfer not turning take the plate off the side belt not just broken missing
This item was ment for the tip why did I collect it
Any how back to what I need what belt do I need there are a few on ebay but none seam to say what this is there are a few qualcast lawn rake re35 but this does not seam to be the same
This is the pics of said item
It would be nice to fix it but it's not worth chancing much for a belt as I dont even know if there is more problems yet I could put a belt on and find some teeth are sheared
but as there are a few belts on ebay for around i 5er i dont mind taking a chance if i can find the right name of this unit and then the right belt as its old its well solid so would be better then a new cheaper unit and i expect will last for a good while if a new belt is foundand it runs fine
and I have taken about 7 large builder sacks (about a meter in diameter) of moss and stuff out of the lawn
