W.olly
- Radcliffe, Manchester
So first maybe project in the new workshop will be to make a weight for the flypress. I have i think, plenty of lead here from old sea fishing weights.
First thing is first though is to sort a smelter/furnace out.
I have these two stoves here which will either be used to heat the workshop or used as a smelter.
Now the vermiculite bricks go up to 1200degC the glass i can replace with steel and line the door aswell with the fire brick.
The whole for top flue can have the crucible in and then the rear flue is used.
Any further thoughts on this folks ? would it get to the temp needed to smelt the lead ? and best way to produce the heat needed
Better condition steel stove. good make.
cheap Clarke one i would rather use as its a bit rough lol.
smelting is extracting metals from ore
