8ob
- Nescient in the vale
Bringing this thread back to life, I need to resize some little end bearings, they are to be 9/16 but the new bearings are 14mm.
No one around this way has a hone small enough, I wonder weather a brand new machine reamer would leave a good enough finish?
Small end bearings/bushes are normally a press fit and honed to size afterwards, do you know the small end diameter of the rods the bearing are normally used in? We have an engineering shop in windlesham that can do this.
Bob
, Is it the dia of the hole in the rod or the required finished size of the bearing you require?
