Too behonest I'm not sure and I don't have one of my ones too hand too check, I believe so though.Do the screws rotate the same way as bahco?
I can never find the point where they auto grip and you only have too apply pressure too one handle
Any adjustable that isn't a proper Bahco!
CIF oven cleaner. ‘Cuts through the worst burned on grease’ blah blah...Very true. A mate works at a chemical plant, his advice when they announced the changes was to go and bulk-buy as much of the original formula as you could find on the shelves, chemists knew the new stuff would be too weak to be effective.
Same as Nitromos paint stripper, as a youngster you *had* to use it in the open air and it would burn though gloves & top layers of your skin in no time. The new stuff is good a good way to get gentle excercise trying to scrape the paint off, no use at all for actually doing what it's supposed to.
I like those use them at workMaybe have a look at these as an alternative:
Bahco 1175-1 45mm 90° Swedish Model Pipe Wrench
Bahco 1175-1 45mm 90° Swedish Model Pipe Wrench available for speedy global delivery. We sell a wide range of pipe wrenches at low prices.www.heamar.co.uk
The generic term for them is 'Swedish pattern pipe wrench'.
The Draper Expert ones (black oxide finish) have a very Bahco look to them and potentially are cheaper, so maybe consider these as well.
E.g. https://gsworkwear.com/products/dra...-with-phosphate-finish?variant=17236503593003
Yeah my old Cemont was like that too. Granted after a while you get used to it, but I expect from a professional grade welding set that anyone can come to it, set x wirespeed and y volts from either a procedure or from their heads, and weld away happily. The "semi synergic" idea of "easier setup" is a complete and utter marketing lie.Had a migatronic like that. Junk
That'll be why we couldn't get more than 220 amps out of it flat-out
It's a machine aimed squarely at professionals who (usually) know what they're doing. They should never have bothered putting the feature in at all, it's more confusing than anything else. Purely marketing BS.Yeah I don’t think the MX350 is really a synergic machine. They are a site CV machine, hardfacing, self shielded etx
It's only money............A bit dear for general spraying down
It's only money............![]()
Odd thing for a Scotsman to say
Roundup selective weed killer. Without Glyphosphate
Absolute garbage. The blurb says ‘results in as little as 3 hours’.
The truth is ‘nothing happened after 3 doses in a week’.![]()
I’ve used real Roundup before and it does the business, but this new hippy, lentil weaving, tree hugger rubbish is a waste of space, you could gargle with it with no side effects.
I am reporting you to the Carver preservation society and the paint police
Bob
Shocked, at your post frankly, I love and worship the god of Knipex.I am going too cause ructions here but I hate both of these.
View attachment 291722View attachment 291723
Utter garbage, and not in terms of build quality I will stress just in terms of no bloody use what so ever. I can never find the point where they auto grip and you only have too apply pressure too one handle, I have too squeeze the bugger out of them too get any purchase on anything, and on the rare occasion I do manage too find the auto grip point on them especially the pliers wrenches they just slip all the time rounding things off, a good shifter is so much better all hyped marketing bull. Going back too using proper pump pliers like made by channel lock and mac tools, they at least actually grip stuff.
Demigod.... wera almighty doesn’t share honoursShocked, at your post frankly, I love and worship the god of Knipex.
