The sprinter that I had before my Tranny had a similar body to this Iveco and that had a large tailift plus a heavy sectional shutter, the type that slides along just under the roof, I made the tailift a bit taller and removed 300kg? of shutter, I will keep a good eye on the weight!That transit uses two external barn doors with a. Ramp inside
extra weight and not needed
if you use springs they can mount under the floor and butt up to the chassis I’d be looking at adding a chassis plate between the near side and off side to stop any flex
tis one of those funny but nice doors that opens alongside the body, maybe there is enough room for the ramp behind the open door, or we put hindges on it but trying to minimise the work...
We could get it weighed when I get some brakes on it, but the payload must be at least a ton, my tranny has 1.2 1.3 ton payload on a good day, plus the extra % for a wet load, plus a bit for luck!![]()
If they are taking 2 horses out then they will be taking 2 people as well...
and anything over 3500kg is now a total nightmare to run, where is the sense in that?Two horses in a 3500kg is a recipe for getting nicked.
the same two horses in a trailer would add up to a good weight as well, not sure how you would tow that lot behind an electric car in a few years time!Two horses in a 3500kg is a recipe for getting nicked.
........Not for personal use its as simple as running a 3500kg horsebox.and anything over 3500kg is now a total nightmare to run, where is the sense in that?
Tesla can do it nowthe same two horses in a trailer would add up to a good weight as well, not sure how you would tow that lot behind an electric car in a few years time!
What changes to your vehicle catagories at age 70? I have up to 7.5ton used to have a class2 but did not renew my medical after my accident 17 years ago!Not for personal use its as simple as running a 3500kg horsebox.
You loose most bits bar A, B, BE, F ectWhat changes to your vehicle catagories at age 70? I have up to 7.5ton used to have a class2 but did not renew my medical after my accident 17 years ago!
very, early 70's, don't want to get a 5ton hobby van and then find I cannot drive it on my licence in four years time!You loose most bits bar A, B, BE, F ect
is your C1 from a pre 97 licence?
That is what I thought, so back to 3.5 ton for me.......... anyone know a good doctor?You will lose 7.5t entitlement unless you pay to have a medical.
