Nathan Levin
- portugal
Hi all
I have 4cm x 4cm x4mm angle iron and need it to span 2m and support the weight of max 150kg, it bends slightly when I stand on it on blocks to check the deflection so my thinking is either
1. add a piece of 4cm x 5mm flat to the underside of the L to make a T, or
2. weld together 2 pieces of 4cm x4cm x 4mm to make a T, or
3. weld together 2 pieces of L 4cm x 4cm x 4mm to make a square tube
What do you think is the best route to create this,
Please bear in mind that this is the material available, there is no option to buy bigger angle, or a RSJ,
The only option is thicker flat
Thanks for your ideas
