Block each fin off with putty or tape or both. How many have you to do?
Thanks - Will do. (Currently waiting on a few bits to set up a purge line.)Lets us know how you get on please
It'll hopefully end up as a static nozzle / guide vane (NGV) assembly for a model gas turbine engine. When I get a bit of time, I intend to start a build thread to document the construction of what will probably end up as an expensive door stop.What’s the part for?
It'll hopefully end up as a static nozzle / guide vane (NGV) assembly for a model gas turbine engine. When I get a bit of time, I intend to start a build thread to document the construction of what will probably end up as an expensive door stop.![]()
Nice, had a feeling it might have been an ngv initially. You a member with the www.gtba.co.uk lot?It'll hopefully end up as a static nozzle / guide vane (NGV) assembly for a model gas turbine engine. When I get a bit of time, I intend to start a build thread to document the construction of what will probably end up as an expensive door stop.![]()
I'm currently building the more redneck version using an 85mm turbo and the help of the guys at https://jetandturbineowners.proboards.com/
