Windy Miller
Semi-Professional Potterer!
- North Kent, UK
Damn - I hope it hasn't ruined it!
It was knackered anyway, so no great loss!
I can't make out what the end is like - is it just a straight fitting with a taper end?
Wait a moment - I'll take another .....I can't make out what the end is like - is it just a straight fitting with a taper end?
Just curiosity, is there a cone in the brass part to match the cone on the end of the threaded part? And can the flow be adjusted by screwing the end in or out?OK - here you go - we were wrong !!! - it does screw off. Hope the below helps
View attachment 288393 View attachment 288394 View attachment 288395 View attachment 288396
Hmmm I’ll have to have a look at mine later.OK - here you go - we were wrong !!! - it does screw off. Hope the below helps
From the design - you would think it would have and would do - otherwise why make it so elaborate.?? I will check in the morning - I've locked up the workshop for the night. If you have not heard from me by mid day - pls PM me to remind me.Just curiosity, is there a cone in the brass part to match the cone on the end of the threaded part? And can the flow be adjusted by screwing the end in or out?
I don't think that either my newer ( c rapper ) oil can or the 60's / 70's one have that feature. They both leak BTW.From the design - you would think it would have and would do - otherwise why make it so elaborate.?? I will check in the morning - I've locked up the workshop for the night. If you have not heard from me by mid day - pls PM me to remind me.![]()
I cannot see the details inside the end of the brass part but can confirm that screwing this in or out, makes no difference to the flow of the oil..... so I guess we have to ask the question, "why did they make the end so complicated?" - I can only assume it is to be able to securely attach something else onto the end of it - flexible tube into a gearbox casing or something similar...????Just curiosity, is there a cone in the brass part to match the cone on the end of the threaded part? And can the flow be adjusted by screwing the end in or out?
Never mind thatNow you've got me photographing oil cans ....
, tell us about the Lotus......
]I don't think I will bother with it then - i tried mine on the little oiler on the vice and it seemed fine - oil went in with no drips.I cannot see the details inside the end of the brass part but can confirm that screwing this in or out, makes no difference to the flow of the oil..... so I guess we have to ask the question, "why did they make the end so complicated?" - I can only assume it is to be able to securely attach something else onto the end of it - flexible tube into a gearbox casing or something similar...????![]()
Just cut up some old bearing outer racesThankyou. I was looking at some parallels on ebay the other day. Really ought to get some sorted.
