All ok I think. Getting about 11lbs of boost so I guess the wastegate opens and closes, and the turbo is doing its job. Not sure what I SHOULD be getting, but it looks ok to me!And?
Your turbo can still be producing full boost but be underperforming - possibly the wastegate is fully closed just to generate enough boost.All ok I think. Getting about 11lbs of boost so I guess the wastegate opens and closes, and the turbo is doing its job. Not sure what I SHOULD be getting, but it looks ok to me!
That's nice, can we see the whole locomotive please.not today but recently made a new shroud for one of the locomotives, no access to slip rollers so had to work with what i had to hand, made a former from a couple of bits of flat bar and a scaffold tube cut into two sections,
it did the job nicley and i then tigged the seam of the shroud with the new welder which was good fun, first bit of ally welding in a while...
View attachment 287390 View attachment 287391 View attachment 287392 View attachment 287393 View attachment 287394 View attachment 287395 View attachment 287396
Done.
The Upol S2085 was very nice to spray, perfect consistency, no runs, used about 100ml for two coats. Started on all the edges then the flat bits. The bottle has some extremely long chemical names - Smells of marzipan![]()
Survived the dentist .
Without getting into details 1000 euros .
But it's not as bad as I've initially thought .
Slowly slowly ,step by step .
I'm only 8 out of 32 ,4 can be repaired the other 4 not .
Is it still there?
Get a bottle of 25% heliumDecided to treat myself and TIG weld up the single easiest part of the platform fab job I've just got in.
Wish I had another 100 amps...! But it got plenty heat into it eventually and welded nicely at 40hz.
View attachment 287463 View attachment 287464
Nah I'm migging everything elseGet a bottle of 25% helium
