wow that's compact!
Here it is...bought from welding supplied direct...I didn't tell them it was me ordering as I wanted to see how the regular service works. So far excellent...I only bought it a couple of days ago.
First impressions...this thing is small and well built....and the case is a proper robust case.
It isn't much bigger than my hyundai....what you can't tell from the pictures is those cables are proper heavy...reckon the cable weight is getting on for the weight of the bare welding machine!
I got the same with mine...stamped "made in Germany".came with a proper Abicor Binzel one
When your next down our way you can mess about with my patonGonna have to try one of these someday
I was reading the manual today...I must have been in a confused state or something. Usually I plug things in and break them....then get the manual out.
So if I'm reading the manual correctly I believe the Paton wire feed (for use with MIG) comes with its own power for the motor....and all I have to do was just plug in the data cable. I could be wrong but that's how I read it...@tanglefeet is that how yours was set up...just 1 data cable and then a separate power plug for the feeder?
Can you tell us who and for what, etc?How many people actually need pulse and how many people know how to use it properly?
For many it isn't necessary or useful, little more than a point for bragging.
For those with a need for it, and know how to use it properly its a godsend.
@HughF has more exp with the paton then me I've just hammered the living daylights out of it when I need to make a weld i know she works im currently messing around with the lift tig function its nice and stable
Me and for the likes of this.Can you tell us who and for what, etc?
I've used Lincolns ewms and kemppis the old type only demoed a fronious and a esab rebel. I'm hoping if the 3 phase model is as good as its single phase it drops all the above pants im currently using a ewm wenga 401 currently and I don't like it I hate setting it up and even after reading the op manual I Still can't get it to run right it runs OK but I'd rather have a Lincoln over that and definitely a paton it. Perhaps the newer ewms are better but the model im using i don't like itWhat other machines are you familiar with - how does it compare?
Happy to send one to you if you fancy giving one a beating BradGonna have to try one of these someday
Happy to send one to you if you fancy giving one a beating Brad![]()
Dunno...if they think it's amazing I kind of want that to wait until I've built up my whole MIG set! You know what these things are like..as soon as something good comes along it either goes up in price or you can't find it anywhere in stock!Would be interesting to see more opinions of people who have used a lot of different brands
