Reman
- Bristol, UK.
Hi all, Mum's got a small polycarbonate water tank on a carpet shampooer that I apparently need to fix. It was dropped and although still in one piece, it's cracked to all hell and back over it's bottom half and leak like a colander. Replacement tanks aren't made for this anymore, and when they turn up second hand they usually cost almost as much as the whole cleaners worth ! So my only cost effective option is to fix the one she's already got.
I'm thinking that if I pour small quantity's of thin resin into the tank I should be able to move it around to coat the inside. If I do it several times until I get a 4 or 5mm coat I'm guessing it should be strong enough to outlive the rest of the machine. Worst case is that I'd also need to glass fibre the outside of the lower tank. The biggest process problem I can see is if I need to plug the outlet valve as it's not a straight shot from the fill hole.
The actual problem is, I've never had to buy epoxy with specific properties before. I've used epoxy in the past that's like water, and some that's almost like honey the second it's mixed. I need something that's thin, but not quite water thin. It also needs to set reasonably quickly. I'm thinking 15 to 20ish minutes until it's starting to gel up or I'm going to loos my rag with having to keep the resin from pooling.
It also needs to be available in small quantity's (A total of 250 to 300ml mixed should be plenty). Money's tight, and I rarely have a need for epoxy, so I don't want to end up with nearly 5 litres of the stuff going off on a shelf for the next 20 years.
So, What do you good folks think would be a suitable product for me to be looking for?
Scott.
Scott.
