can i ask the question can the wire feed be changed off another welder if seen one on fleebay its made off plastic its for a snap-on but looks better than whats on sip plus my dad as a clarke welder that the pcb as gone on it looks better
I wouldn't hesitate to change/upgrade the wire feed. I think it would be quite an easy and very worthwhile thing to do. You may need to drill a couple of new holes in the panel but that's simple enough. Both motors are probably going to be quite closely matched so the spin speed should be OK and the PCB should 'accept' the new motor. I can't see how hooking up the main cable (wire, HT and gas lines) should be very difficult, either.
