I concur.ha ha start afresh! its quicker and easier! ask me how I know
Yep, enough headroom to lift a car, quite high.Ooo, bigger than it looked from the outside... I wondered if you had headroom for a lift with a car on it.
If you seal the corrugated metalwork, concrete block some pillars in for the I beam you can just insulate the inside. You won't have condensation issues. I'm never sure about kingspan type stuff and fire - it needs to be covered with something?
That's an absolutely brilliant idea, 10 points that man. Thanks.Would it be feasible to prop up/level the entire roof structure and build in new sides off the new slab?
Bob
No, too much work.ha ha start afresh! its quicker and easier! ask me how I know
good point...Matt you need to start again. That sheds not near big enough for all the "stuff" you keep buying and hiding from the wife.![]()
not on my budget. And it's a restoration.I concur.
Order a kit building the right size. Bing hang bosh, job done in 3 or 4 days.
I refurbished an old stone barn. For the roof structure it was far cheaper and quicker to just order pre made trusses through a builders merchant than it would have been remaking trusses etc.
Whether I use concrete or breeze blocks, there's going to be 80mm of insulation, 19mm ply, so shelves will have to be attached to verticals attached to the ply (I think).Avoid breezevlocks. Any fixings just fall out over time
Ok, I got you.True, but what stops your ply falling out.
the only benefit to breezeblocks is their r value and they’re easier on the bricklayers back. You’ve already got the insulation. So your only benefit is the weight.
Yeah, me too, going to put up mesh and grow climbing plants up it too.I like the rustic tin/corrugated
Ok, I got that, never thought of the difference before.No to breeze blocks from met too...
Block work is a very therapeutic pastime..Ok, I got that, never thought of the difference before.
never really done much block work.
Never get anything done then....![]()
I would happily floss with that chain
Bob
any good at hiding
as this time id need to be smuggled across![]()
just to note here i wouldnt want a wood burner near anything that is oiled as it would suffer drying out the oilI'm going to divide the workshop.
2/3 Machine / welding shop.
1/3 2 post lift, for working on cars and vans, a wall between the two, so the machine shop can be kept nice and warm, I've a spare wood burning Rayburn to go in there.
Ceilings at 2.2 meters +-.
Here's the rough plan.View attachment 285330
