arther dailey
- England
might also try stacking shelves....
If you can work out which of the wires from the selector (NORMAL, STITCH, SPOT(?)) go to where on the pcb then you might find there is a device "stuck on" transistor maybe that is holding it in stitch mode or that a track from the other functions is also broken stopping them activating and the machine defaults (via circuit layout) to stitch mode. Can I assume that each of the three relays is for one of the modes ? Does the stitch timer still adjust the delay even if selector is set to one of the other two modes?Yes getting there, but I now see why so many autolynx items on this forum end up on an unfinished note !! If I had put the hours in at tesco stacing shelves I would now own a kemppi.......Arther ps any ideas on permanent stitch mode?
constant weld,nada,ziltch..ah well.
I would if I could but dont think I have it anymore, ended up selling the mig as is on ebay ..pls could i have a copy ov your wire diagram
thnx
