- Never Never Land
Hi Guys, I have some of the above mentioned headphones. Had them for just over 2y now so out of warranty
. I love them before anyone slags them off. I worked out I have done easily 2500hours of use with them and they’re still good, apart from the screw falling out the other day which is super annoying.
I took the screw out from the other side to measure it and I’d kind of like some clarity and maybe info on where to source the size I think it looks like.
Right so the longer screw is another I had M2 x 16mm, the tiny one is what I need.
Measuring the diameter here is imperial the metric size is 1.53mm
The length of the screw is this. That in metric is 4.02mm
From the 4mm length I was able to count the threads which look to be around 12.
I devided 25.4 by 4 to give me 6.35 then multiplied that by 12 which gives 76.2. Cross referencing the to my zeus book it looks to be No 0 ANF which is 80tpi as you can see, the imperial OD is the same as well.
If I am correct where do I get something similar?
thanks
thanks
