- Never Never Land
Hi Guys, I have some of the above mentioned headphones. Had them for just over 2y now so out of warranty
. I love them before anyone slags them off. I worked out I have done easily 2500hours of use with them and they’re still good, apart from the screw falling out the other day which is super annoying.
I took the screw out from the other side to measure it and I’d kind of like some clarity and maybe info on where to source the size I think it looks like.
Right so the longer screw is another I had M2 x 16mm, the tiny one is what I need.
Measuring the diameter here is imperial the metric size is 1.53mm
The length of the screw is this. That in metric is 4.02mm
From the 4mm length I was able to count the threads which look to be around 12.
I devided 25.4 by 4 to give me 6.35 then multiplied that by 12 which gives 76.2. Cross referencing the to my zeus book it looks to be No 0 ANF which is 80tpi as you can see, the imperial OD is the same as well.
If I am correct where do I get something similar?
thanks
. I love them before anyone slags them off. I worked out I have done easily 2500hours of use with them and they’re still good, apart from the screw falling out the other day which is super annoying.I took the screw out from the other side to measure it and I’d kind of like some clarity and maybe info on where to source the size I think it looks like.
thanks
