eLuSiVeMiTe
Small quantities.Wow, you guys know how to over-engineer a solution
The required ratio in the OP is 3:1 by volume, why complicate the issue with weight when the 2 materials will likely have different densities?
30ml of paint. 10ml of hardener. How much is left in the pot and on the stick? Not an issue in large quantities.
I don't get what's so hard about mixing by weight
A bit of time finding out the gravity of the two liquids if the data sheet doesn't give a weight ratio.
