I have a Butters AMT 180C. The wire feed has got really tempermental. Its getting to the point that its impossible to weld. I can stand next to the machine and it will reel out wire if i pull the trigger. The minute i get into position to weld (generally an awkward spot under a land rover) it spurts out a bit of wire and then jams. It will pull through easily if there is no tension on the wire feed so I dont think there is a jam in the lead. Thats a new evo 25 (I think). The tension seems ok on the feed rollers. If i loosen it off much more it wont feed, it is nearly as tight as it will go.
Any ideas?? Will be getting the arc welder out at this rate!
